Message |
I did one last week on a TT with an aftermarket rad. Took me a couple hours but I’ve got a hoist. Recover refrigerant, Splash pan off, drain coolant, tension rods/mounts off, sway bar off, Drop rad out the bottom. loosen ac belt, remove fan from water pump. Remove compressor mounting bolts, pull compressor forward and undo lines. Compressor out downwards.
